Fuel lines? What size
About to drop the 5.3 in my v6 truck. Engine is a 5.3 with heads, cam and nitrous. I have 8.1 marine injectors and an in tank Walbro in stock bucket. The stock v6 hard lines are still there but the soft line going to the tank/fuel pump has all been cut. Trying to figure out what size line and connectors I need to get.
That's correct. 1/16" is 1 -an. If it's a show truck, I would cut the flex off both ends of the OEM V6 tubing, use tubing compression to -an fittings to connect either a ss braided hose or startlite/similar then to those fittings I listed above.
I'm not sure I understand your question about the NX system. Most people just adapt the fuel supply line to the test port on their oem rail. That's what I did moons ago at least.
Bdanielshd
02-25-2016 03:32 PM
oxidizr
05-06-2002 08:04 AM
