drive by wire
Old 11-28-2014, 09:07 AM
verbal_78's Avatar
Default drive by wire
For those who have done an LSx swap with DBW, what did you do about the pedal and TAC? If the engine didn't come with them, where did you get them? Thanks.
Old 04-10-2015, 08:19 PM
btlegacy's Avatar
What year is the ECU and throttle body? Its best to match to the same year. I have also had success with using 02 Corvette Pedal and TAC on all kinds of stuff as long as it was older than 05
Old 04-11-2015, 08:32 PM
12 Second Club
Funkster's Avatar
If you are interested I am selling the entire DBW setup from my 03 Silverado as I am converting to cable. Mine would be matched set of Pedal, sensor, Throttle Control Unit w/Harness from pedal to Unit then the throttle body itself.
I can also sell the PCM/ECU that matches the setup, but it has a custom tune on it so you would have to flash whatever tune you want on it.
ARC
57
02-21-2022 10:54 AM
slowmo934
09-09-2015 12:24 PM
greedygenius
09-03-2015 06:51 AM
Mossyoakglock
07-17-2015 08:30 AM
Quick Reply: drive by wire
