drive by wire
For those who have done an LSx swap with DBW, what did you do about the pedal and TAC? If the engine didn't come with them, where did you get them? Thanks.
What year is the ECU and throttle body? Its best to match to the same year. I have also had success with using 02 Corvette Pedal and TAC on all kinds of stuff as long as it was older than 05
If you are interested I am selling the entire DBW setup from my 03 Silverado as I am converting to cable. Mine would be matched set of Pedal, sensor, Throttle Control Unit w/Harness from pedal to Unit then the throttle body itself.
I can also sell the PCM/ECU that matches the setup, but it has a custom tune on it so you would have to flash whatever tune you want on it. |
