WEAPONS What? Trucks and weapons don't go together?
Dpms AR-15 trigger issues
Old Aug 13, 2012 | 07:09 PM
getchusum99's Avatar
Default Dpms AR-15 trigger issues
I was at the range Saturday shooting. I put about 100 rounds through my rifle when the trigger got really hard. It would still fire but was stiff as hell. I had 120 rounds with brass casings, and 40 rounds with steel casings. Didn't load the steel until the last few clips and then I started having issues. Any ideas?
Old Aug 13, 2012 | 07:12 PM
2000chevysilverado's Avatar
is the rifle new first time shooting
Old Aug 13, 2012 | 07:20 PM
It had maybee a hundred rounds through it from the previous owner
Old Aug 13, 2012 | 07:27 PM
nonnieselman's Avatar
I had a primer blow out and get stuck under my hammer and lock mine up.
Take the upper off, hold your hand on the hammer very slighlty.
Pull the trigger and see what everything is doin.
Called a function check.
Possible a trigger or hammer pin broke.
Ive had that happen a few times.
Take the trigger group apart and inspect it and snap picks
Old Aug 13, 2012 | 08:35 PM
Function check
Charge handle
Switch from safe to semi
Pull triger and hold down on trigger
Charge handle again
Let go of trigger should hear a click if so all good
I'm thinkn your bolt is dirty between firing pin and bolt set bolt in some carbon softner or gun oil and clean it up and clean ur triger assembly and oil sounds like little dirt or carbon build up 100 rounds in a ar gets dirty quick
Old Aug 14, 2012 | 05:54 PM
Thanks guys. Will do
Old Aug 16, 2012 | 12:35 PM
I love Parts and brake cleaner.. blast the lower with that stuff and it blows all the crud out. i use it all the time
Old Aug 26, 2012 | 10:35 PM
jared91's Avatar
sell it and buy a colt or bcm problem solved cost the same and loads better
Idryfly5
Sep 2, 2022 08:55 PM
TAPyvehc93
Sep 14, 2015 01:22 PM
dselby25
Sep 11, 2015 05:03 AM
97gmc
22
Sep 8, 2015 10:56 PM
Boyes50
Sep 8, 2015 12:06 PM
