WEAPONS What? Trucks and weapons don't go together?
AR-15 Pins
Old Feb 1, 2013 | 02:17 PM
texasglock23's Avatar
I've never had an issue there, I had worse luck with the front take-down pin more than anything.
Old Feb 10, 2013 | 03:31 PM
02white6.0's Avatar
I just use the razor blade trick when assembling the front take-down pin, it's a little awkward by yourself but can be done.
Old Feb 10, 2013 | 06:41 PM
yeah, those SOB's can be tricky. There is a specialty tool, but I didn't want to purchase it
Old Feb 13, 2013 | 04:32 PM
nonnieselman's Avatar
The pliers trick worked great!
got a guy in the shop making me a long tap that will thread it and i can be back behind the lower so it wont get scratched up.
Old Feb 19, 2013 | 03:56 PM
Seekins precison does that instead of roll pins
I just bought a Stiller Predator XT and the rear pin for the takedown pin has got a set screw so everytime I take the butt stock off the spring stays intact
Old Mar 9, 2013 | 11:01 AM
02white6.0's Avatar
Originally Posted by MPFD
I don't know how set screws would work in that application due to the catch needing to have a range of motion. but I am a huge fan of using the set screw on the gas tube that comes with Kies Gen II adjustable gas block.
Use a set of plain old pliers, tape up the jaws so you don't scar the the aluminum and just push the roll pin through with the pliers set at the wide jaw position. I learned this from Scott at SD and it works great. Just get it all lined up and start the roll pin and it will push right into place with out any hesitation. using a Hammer and a Punch on the that part is awkward and can cause damage as you have seen...
Used this trick last weekend when assembling a couple of lowers, works great and MUCH better than using a punch and hammer.
Porscharu914
14
Jan 20, 2016 10:45 AM
Silver8ado
Sep 30, 2015 11:42 AM
trxmxzx
Sep 29, 2015 07:42 AM
kalikid06
Sep 20, 2015 07:46 PM
99bluefirebird
Sep 17, 2015 08:05 PM
