won't idle, cam position sensor?
Old 01-25-2012, 10:13 PM
  #41
Well, time to revive this one as I have the tune done but still have that p0343 code still there. Any suggestions?
Old 01-25-2012, 10:49 PM
  #42
Custm2500's Rude Friend
1FastBrick's Avatar
P0343 Camshaft Position Sensor Circuit High Input
I see this originally started back in 06 you also mentioned a wireing Issue at one point.
Did the code ever go away???
If the wireing is sound and the sensor is reading the only other thing would be an issue with the cam.
check out what happened to this guy.
Help!: dtc p0343
Old 01-25-2012, 11:39 PM
  #43
Help!: dtc p0343
No the code has always been there. But as my winter driver, I don't get out in it much. Way back when I did take the cover off and inspect and all was in order. This weekend I'll do a voltage check on the harness.
Old 01-25-2012, 11:49 PM
  #44
1FastBrick's Avatar
Sorry it wasnt ment to be read as you left something lose but maybe there is an issue with the cam shaft it self. after all you mentioned this code has always been there since the swap.
My point was that if there is an issue with the cam shaft being to long or short you may have an issue like the guy with the loose bolts.
Old 01-26-2012, 12:03 AM
  #45
I'm hoping it's not the cam as I don't have the time and can't have my truck down for anything more than the weekend intill the summer when the bike comes out.
tweeder
09-18-2015 11:02 PM
InsaneDomestics
07-27-2015 02:42 PM
atxlt
07-20-2015 11:06 PM
Mossyoakglock
07-17-2015 08:30 AM
Suburban2500
07-14-2015 02:10 AM
Quick Reply: won't idle, cam position sensor?
