Windshield wiper motor bench test
Old May 13, 2012 | 07:31 PM
snowshoejeep's Avatar
Exclamation Windshield wiper motor bench test
How can I bench test my 93 wiper motor. I do have the steering column out of the truck and can temp a harness between the two. Just don't know what the orange and black wires are going to the wiper motor. (maybe 0range is 12v and black is ground?)
What function do the Grey, white and purple wires control on the wiper stalk to the wiper motor?
Thanks for your help....
Old May 16, 2012 | 10:07 PM
Did yop keep the delay module black box with aluminum fins that is attached to wiring coming out of steering column.
Old May 16, 2012 | 10:58 PM
These are connector id at the motor
white on connector going into the delay module is the same 12V that powers the motor and needs a 25 amp fuse.
Pink out of column is 12 v to wash pump
Orn from column to motor is delay wipe
purple from column to motor high speed
gray from column to motor low speed
WHT at motor 12V key on
Black ground
Old May 31, 2012 | 06:01 PM
Red face
Rut-Ro, didn't see that on the doner vehicle...
Guess I better go back to see if it's there
Is the module on the dash harness or on the column harness ??
Old Jun 1, 2012 | 02:04 AM
IT goes on white connector at bottom of column plugs and then plugs into the dash harness. I have a few if you need one also.
Old Jun 3, 2012 | 06:19 PM
Red face
Yep, again...man I'm always mis'in something,
Price to:
Dummy (Or Rick) Landerholm
1022 Yellowstone Dr.
Grapevine, Tx 76051
Thanks again...
Old Jun 4, 2012 | 09:54 AM
Exclamation
Hey Chris....
I thought the delay was built into the module on the wiper motor...??? I could not find a separate module on the donor truck.
Rick
Old Jun 6, 2012 | 08:38 AM
Exclamation
Any thoughts....
TXsilverado
Nov 26, 2015 10:54 AM
black6spdz
Jul 16, 2015 01:32 AM
