Where do I need to send my PCM for a 80e segment swap?
Old Apr 1, 2012 | 08:32 PM
sleeperlqx's Avatar
Default Where do I need to send my PCM for a 80e segment swap?
I need to have my PCM segmented for the 80e tranny. Im trying to do this swap different, and not run the relay mod on it. So I will wire both sensors to the PCM, and get the NEW segment. I need to know where do I do this> ? I would also like I few updates in the tune as well.
Old Apr 2, 2012 | 04:52 AM
TIM Z's Avatar
11 sec. Truck Mod
If you have or use HPT , send them your tune and they will do the segment swap.
If you have EFI Live you can do it yourself, there is a tutorial on EFI Lives' website by Blackbear ( different user name though).
Old Apr 5, 2012 | 06:42 PM
sleeperlqx's Avatar
Can Black Bear redo my PCM for segment swap and maybe a LOGing tune? Can he build off of my PCM4less street tune and me loging data and updates for my changes? My main concern is the segment swap. And If all can be done with 1 place, might as well choose them, since I relocated far from any tuners.
Old Apr 5, 2012 | 09:03 PM
brent1976's Avatar
11 Second Club
What about Alvin@PCM4less. It's in your sig.
Old Apr 6, 2012 | 06:55 AM
Gadgetized's Avatar
Any of the sponsors can do it for you if PCM4less did not lock your computer. They might even be able to do it if it is locked it, I am not 100% certain about it. You will either have to swap the wires around on your harness (this is extrenely easy), get an 80e adapter harness, or have an 80e harness. I like Wheatley or Klugg. FWIW
Old Apr 6, 2012 | 06:59 AM
CalEditor@PCMCalibrators's Avatar
FormerVendor
I can tell you I know of 2 ways to do it. The way I used for years and most shops use is not the best way to do it at all. I was taught the correct way from a guy that would know and I fined that it works much better.
Most tuners are not allowed to tune in the complete calibration. I have found 4l60E and 4L80E parameters out of the normal tuning portion of the calibration. You can still make the segement swap using tuning software E or T and it will work, but it is a lot of work and it still isn't 100%
We had a lower price for Segemnt Swaps and if you contact me I can work out a price
XL7
May 5, 2022 01:48 PM
lo&sloSierra
Aug 30, 2015 02:36 AM
1slwgto
Aug 16, 2015 06:40 PM
iregret
Jul 27, 2015 10:32 PM
