Where do I need to send my PCM for a 80e segment swap?
I need to have my PCM segmented for the 80e tranny. Im trying to do this swap different, and not run the relay mod on it. So I will wire both sensors to the PCM, and get the NEW segment. I need to know where do I do this> ? I would also like I few updates in the tune as well.
If you have or use HPT , send them your tune and they will do the segment swap.
If you have EFI Live you can do it yourself, there is a tutorial on EFI Lives' website by Blackbear ( different user name though).
Can Black Bear redo my PCM for segment swap and maybe a LOGing tune? Can he build off of my PCM4less street tune and me loging data and updates for my changes? My main concern is the segment swap. And If all can be done with 1 place, might as well choose them, since I relocated far from any tuners.
Any of the sponsors can do it for you if PCM4less did not lock your computer. They might even be able to do it if it is locked it, I am not 100% certain about it. You will either have to swap the wires around on your harness (this is extrenely easy), get an 80e adapter harness, or have an 80e harness. I like Wheatley or Klugg. FWIW
I can tell you I know of 2 ways to do it. The way I used for years and most shops use is not the best way to do it at all. I was taught the correct way from a guy that would know and I fined that it works much better.
Most tuners are not allowed to tune in the complete calibration. I have found 4l60E and 4L80E parameters out of the normal tuning portion of the calibration. You can still make the segement swap using tuning software E or T and it will work, but it is a lot of work and it still isn't 100%
We had a lower price for Segemnt Swaps and if you contact me I can work out a price
lo&sloSierra
Aug 30, 2015 02:36 AM
iregret
Jul 27, 2015 10:32 PM
