Where is all my fuel going?
Old Feb 24, 2008 | 07:58 PM
Whippled 496's Avatar
Default Where is all my fuel going?
I cant seem to figure this out. Setting up both my MAIN VE table and my BOOST VE table and the values that are being logged are off quite a bit from values entered in the tables. For example:
{B0101} MAIN VE
In the attached log, frame 1361 shows my BEN factor @ 1.037. This is at 1506 RMPs x 50kPa. When you refer to the MAIN VE table, this area shows that my Grams/Cyl should be about 0.4387, however the log at frame 1361 shows my Grams/Cyl at 0.4077.
{A0009} BOOST VE
In the attached log, frame 977 shows my BEN factor @ 1.061. This is at 4616 RMPs x 135kPa. When you refer to the BOOST VE table, this area shows that my Grams/Cyl should be about 1.7645, however the log at frame 977 shows my Grams/Cyl at 1.6931.
So for whatever reason, something is pulling fuel and I cant find it. Its not my IAT multiplier because my IATs are 80*. Its not ECTs, they are where they need to be. So i was hoping someone could sift through this tune-n- log when they get some time and post up some possibilities if they could please. I know I am running out of injector too, and i dont know if the new exhaust could have anything to do with that or if its because i pulley'd down one size.
Here is my tune and a log of that tune...
File Type: efi
File Type: tun
Fast86z
Aug 23, 2015 12:35 AM
05GMC4.8
Aug 7, 2015 09:55 PM
Mossyoakglock
Jul 17, 2015 08:30 AM
jrplz
Jul 9, 2015 12:07 AM
