When is VE in control vs. MAF?
Old Mar 21, 2007 | 11:34 PM
  #41
Hawk179's Avatar
Originally Posted by 12secSS
Chart on!
The only injector maker I have data from is Mototron, others are like it is a trade secret. I found a website that had an extensive list of injectors and some data, I will find it and forward it to you (could be you have stumbled upon it). I will ask those that I know (as well as make a post on the HPT forum), of how it works and relay that info to the enthusiasts. I agree about playing with numbers, I much prefer to understand their function then mearly adjusting them.
Good luck with your schooling.
Why would you need to play with Injector offsets? So far I have never really had a need for it. Been there done that.
RIck
Old Mar 22, 2007 | 10:03 AM
  #42
dc_justin's Avatar
Hello Dave
RIck
Larger injectors have a larger pintle and take more time to open given the same amount of current delivered to them. With commanded pulse widths that are very low, the injector may not even open at all. At that point you need to tell the PCM to add in x amount of extra time when opening the injector to have them deliver the proper amount of fuel.
This "phenomena" can be seen easily with a set of Mototron 60s. When pulse widths get down below about 1.5ms, the injectors will struggle to open and the AFR will start to jump around. Get down close to 1ms and the injectors won't even open at all.
Old Mar 22, 2007 | 01:11 PM
  #43
Hawk179's Avatar
I knew that, but you still dont need to touch the offset table. There are "other" tables for that stuff.
Rick
Old Mar 22, 2007 | 01:25 PM
  #44
RedHardSupra's Avatar
like what other tables?
Old Mar 22, 2007 | 02:08 PM
  #45
Hawk179's Avatar
Well, from your previous posts, it sounds like you are doing just well enough. So I will stick to what works for me.
RIck
Avalanche2002
Nov 30, 2015 07:31 AM
JordanH
Oct 3, 2015 03:59 PM
02AWDAWSDenali
Oct 1, 2015 05:08 PM
old motorhead
Sep 29, 2015 08:22 PM
