When is VE in control vs. MAF?
Hi, all. I've been studying up on tuning; HPT is on the way. One thing I'm not clear on is WHEN (under normal operation) the VE table controls fueling and WHEN the MAF controls fueling. And is it VE _or_ MAF logic, or are the values combined or averaged in the logic at times?
I'm trying to understand the control software behind the tables is how I would state the question. What makes me ask is that we have to disable the MAF during VE tuning. It seems like once we re-enabled the MAF then the VE tuning would be for naught... clearly there are times when MAF computations are in charge and there are other times when VE computations are in charge of the result.
Please help me understand this.
Thanks!
Mike
PS- I see where some people disable the MAF altogether and run just SD logic all the time- thats seems clear.
Thanks!
Mike
Thanks!
Mike
Thanks!
Mike
Both the ve table and the maf table need to be tuned once they both line up and jive togethor it makes for very consistent fueling throughout any type of weather and you can tell a difference in the way the motor will run. I currently run both and on the cars I tune, both tables are adjusted and it works very well. Look at the sticky at the top for the methods I use.
Originally Posted by 02sierraz71_5.3
maf more at part throttle operation and not so much at wot
Originally Posted by dewmanshu
elaborate please. We have a table to change this?
i have never played with that...BUT, if I lowered that to say, 100RPM I could be running on MAF only at all times and then use the MAF histogram and be set right? AWESOME! (not leaving it so but just for tuning the MAF)
or you can lower the fail over hz so anytime the maf reads over a set amount it goes to solely Ve table
thnx
