What PDM do I need to add tpms system on a 2007/Silverado classic
Old Mar 21, 2016 | 05:38 PM
Jaxon2580's Avatar
Default What PDM do I need to add tpms system on a 2007/Silverado classic
Hey guys,
I have an 07 Silverado classic LT(cloth seats) and wanted to add tire pressure sensors so I've put in GM EZ sensors with the rubber valve stems 433mhz and tried using a tech 2 to activate the system. Here's my issue, I've found in the passenger door module in diag section you can enable it but when I hit enable it still says the system is inactive. I believe I have the right door mudule UK3 which is the one that allows me to see individual pressures but I'm not sure why it won't allow the system to enable, do I need to go into the serviceable programming section and re flash my BCM or do I have the wrong module? If anyone knows how to do this or has a bit of experience with the tech 2 ID appreciate it!
Mean Green z28
Nov 3, 2016 09:43 PM
Wolftrk99
Jul 29, 2016 01:07 AM
kunzy420
Mar 6, 2016 11:28 AM
renright83
Feb 25, 2016 05:58 PM
John Twar
Feb 21, 2016 04:14 PM
