What am I doing wrong STFT
Old 11-08-2017, 01:50 PM
  #21
Jonblarc7's Avatar
And I would do that under PE correct?
Old 11-08-2017, 02:00 PM
  #22
madmann26's Avatar
Yes.
However, if you still have LTFTs turned on and they are more than +-5, this gets factored into your commanded PE and skews it.
Most of us disable LTFTs altogether. There is no harm in doing it.
Ideally, what you command in the PE table should match what is on the AFR gauge pretty close.
As FFDP suggested, lean it out some. This is known as rich knock.
Old 11-08-2017, 02:05 PM
  #23
FFDP's Avatar
Correct, the power enrichment EQ ratio is what is used during WOT for a commanded AFR.
Staying around a 12.0 commanded is still safe if you don't have a wideband hooked up into your log files. For future reference PE EQ ratio is a set it and forget it table. Once you pick and AFR/Lambda to run you tune it to achieve the number. Like if you request 12.0 but the wideband showed 12.3, it would be slightly lean of commanded. You would add in fuel via the MAF/VVE to bring it down to meet the commanded number. Same thing but the opposite if it was 11.7 with a requested number of 12.0, removing fuel would be wanted.
Using a little less fuel could help with the knock here, it's a simple test to see how it responds. If knock is still present, lower the commanded timing at WOT. If 25-26 commanded timing is too high and showing knock, lower it to 22ish or where ever the vehicle see's fit.
Old 11-08-2017, 04:24 PM
  #24
Jonblarc7's Avatar
I will make changes tonight and log again.
Thanks
Guys I'm learning alot
Old 11-09-2017, 10:49 AM
  #25
Jonblarc7's Avatar
Well I got commanded AFR to 12.23 and only had 1 degree of KR under WOT. So that's better.
But if you look at the 8 min mark of the log I still get a random 4 degrees of KR. I also get random 1 degrees of KR at random times.
File Type: hpl
Old 11-09-2017, 10:51 AM
  #26
Jonblarc7's Avatar
I still need to disable burst knock table. I forgot to do that last night.
Old 11-09-2017, 12:31 PM
  #27
Jonblarc7's Avatar
Burst knock table didn't really help. One pull would be no knock then the next pull would be about 3 KR. Then I still get the random 3 degree out of no where or just a random 1 KR.
I'll post the last log when I get home. The truck feels better though.
Old 11-09-2017, 04:57 PM
  #28
I have a gauge for that
Atomic's Avatar
Did you take 5 degrees out of the whole table and see if it still happens?
Old 11-09-2017, 05:20 PM
  #29
Jonblarc7's Avatar
No sir
Are you talking about the High Octane table??
Old 11-09-2017, 06:51 PM
  #30
Atomic's Avatar
Both high and low. It's probably false, but to find out you can pull timing or put in good fuel to find out.
