What AFR to command ??
Old Feb 26, 2006 | 01:48 PM
Yelo's Avatar
Default What AFR to command ??
My Power Enrich Fuel Multiplier vs. RPM table varies AFR from 13.5:1 to 12.1:1 over the rpm range from idle to 6000rpm with 12.1:1 commanded from 4800rpm-up....does this sound about right or should I be looking for a different commanded AFR ???
Old Feb 26, 2006 | 06:04 PM
dc_justin's Avatar
Hello Dave
Probably don't need it quite that rich for N/A. 12.5-12.7 should be rich enough.
Old Feb 26, 2006 | 07:49 PM
chrisj6's Avatar
I would back it off to 12.6 and see hwo that is, if it seems a bit sluggish even backing it down to 12.8 is ok. Mine runs its richest at 12.8. PE is 13.2-12.8.
Chris
Old Feb 26, 2006 | 10:21 PM
You'll make more power with a leaner mixture probably about 13.5 to 1.The trick is in the combination of optimized timing and a just rich enough fuel mixture to avoid detonation.The only reason to go with a richer mixture is to accomadate a power adder.
Old Feb 26, 2006 | 10:28 PM
04Denali's Avatar
So what it the ideal AFR for a supercharged 6.0
Mark
Old Feb 27, 2006 | 12:56 AM
Last Call's Avatar
TOTM: January 2007
I had my truck tuned today, new cam, springs, oil pump, and chain. Tuner said 12.0 was relatively safe for a boosted application.
Old Feb 27, 2006 | 07:35 AM
dewmanshu's Avatar
Moderately Differentiated
Mark
depends greatly on your setup, but if your stock besides the radix...12 is supposedly safe. I like staying under 12 for longevity. I am in a hurry to get quick 1/4 times, but not in a hurry to burn a piston up.
Old Feb 27, 2006 | 10:50 AM
Yelo's Avatar
OK....with 10.5:1 CR what kind of timing and AFR combo should I be looking for then ??
Old Feb 27, 2006 | 11:17 AM
dc_justin's Avatar
Hello Dave
Target the same AFR.
Timing... there isn't just some number that can be thrown and that will apply. Your best bet is to get it on a dyno and steady state tune timing table. Will take you a few hours, but when you're done, your timing table will be near perfect.
pittman
Jan 19, 2016 07:06 AM
Isak81
Aug 29, 2015 01:44 PM
mz00516
Aug 23, 2015 12:19 PM
creekrat
Aug 2, 2015 01:27 AM
