weird electrical problems
Old Sep 28, 2013 | 01:57 PM
bbowerman's Avatar
Default weird electrical problems
okay so my 3-4 clutches were going bad so i drove home to my garage. all gauges worked. that being said i pull the tranny take it and have it rebuilt and put it back in and do the normal fill the tc up and add 5 quarts of fluid go and start the truck and notice every gauge in it doesnt work??? neither does prnd321 so i bought a new neutral safety switch didnt fix it. sooo i go ahead and leve it running in neutral fill the fluid go down the road and only have 1st and reverse???? any help appreciated
Old Sep 28, 2013 | 02:13 PM
whippled 8.1l build's Avatar
have you checked to see if you pinched wires in the bell housing to the engine?.. happens more often they you would think if your not paying attention to them
Old Sep 28, 2013 | 02:22 PM
bbowerman's Avatar
i didnt see any pinched but i will have to go check again with a flashlight cause its dark and rainy here
Old Sep 28, 2013 | 02:23 PM
check that and all your fuses..
Old Sep 28, 2013 | 02:24 PM
bbowerman's Avatar
any specific fuses or just check them all?
Old Sep 28, 2013 | 02:28 PM
not enough knowledge to say a specific one so i would just check as many as you can after checking for the pinched wires..
Old Sep 28, 2013 | 02:31 PM
bbowerman's Avatar
okay well im gonna drive a few miles then ill report back
Old Sep 29, 2013 | 08:57 PM
N20zuki's Avatar
Did you remove the ground on the back of the passenger side head for any reason?
Old Oct 3, 2013 | 08:17 AM
Chevy67don's Avatar
Registered User
I second that. I think it might be that ground strap many forget about at the back of the head.
drummer0415
11
Oct 24, 2015 08:16 PM
kalikid06
20
Oct 13, 2015 07:37 AM
SlvrSierra4.8
Oct 1, 2015 09:39 PM
TAPyvehc93
Sep 14, 2015 01:22 PM
Alvin@PCMofNC
Sep 3, 2015 06:38 AM
