very little bottom-end after tune ???
Old 05-25-2010, 06:46 PM
silverado2000's Avatar
the mass air is bad on my truck we shut it off yesterday. the timing is at 22 deg. at 2500rpm if that helps, we turned off and unpluged the knock sensors cause we are getting false knock i hope, and the truck was still pulling timing after the knock sensors were unpluged so he changed the timing to only go down to 22. this tuning stuff really confuses me with the L-trim,timing, ect. so sorry if what i just wrote makes no sense.
also my trucks a 2000 i already got rid of the 2000 computer for the 2002 computer.
Old 05-30-2010, 06:14 PM
454SuperSport's Avatar
Sounds like your tuner is using some of the old school hacks to try and make it work. There is a problem somewhere that needs to be addressed first instead of masking the symptoms.
Old 05-31-2010, 12:17 AM
any idea of what it could be ?
Old 05-31-2010, 09:15 AM
TXsilverado's Avatar
go ahead and put your tuners name out there. i have an assumption of who your tuner might be based on you location. if im right, he is one of the best in the business.
Old 05-31-2010, 11:37 PM
9 Second Club
It says nelson tune in his sig.
Old 05-31-2010, 11:58 PM
nelson is the tuner. everyone says hes the best but he cant tell me whats going on with my truck? im in no way bashing them im just getting annoyed and want to know why my trucks so slow a geo would blow my doors off.
Old 06-01-2010, 12:23 AM
BigRed Cummins's Avatar
Something is definitely wrong. You should be able to wrinkle pavement. If I read your post correctly, then your maf is bad? If so, that needs to be corrected asap. Hows your fuel pressure? Also, I would replace the knock sensors if they are reading false knock. Un-plugging them is probably what is causing the computer to pull timing, because it cant even sense if the knock sensor is there. What octane fuel are you using? Also, is the tuner getting the truck? Or are you just sending him a computer?
Old 06-01-2010, 12:41 AM
running 93, the tuner drives the truck around with me for about an hour each time trying to fix it all, and i plan to replace all the sensors that are bad(maf, knock).idk what the fuel pressure is i need to put a gauge on it. the fuel pumps only about 2 years old with a new fuel filter.
Old 06-01-2010, 12:47 AM
I would definitely start with replacing the MAF.
Old 06-01-2010, 12:56 AM
it is turned off in the tune so it should not be changing anything.
Quick Reply: very little bottom-end after tune ???
