V2 to LC1 issue
Old Sep 1, 2011 | 05:28 PM
2007chevy5.3l's Avatar
For the record I just did a free air calibration and got the same results.
Old Sep 1, 2011 | 06:57 PM
BlackGMC's Avatar
Resident Retard
You could still log analog.
Old Sep 1, 2011 | 07:54 PM
Got an analog cable i can borrow Corey?
Old Sep 1, 2011 | 07:57 PM
smokeshow's Avatar
Mod with training wheels
Ouch :/ I just bought an LC1 as a standalone WB, hopefully I don't get the same results with the serial connection...
Old Sep 1, 2011 | 08:11 PM
Let us know if yours doesnt work... Im curious as to why these things go out or stop working with serial logging.
Old Sep 1, 2011 | 08:24 PM
BlackGMC's Avatar
Resident Retard
No special cable needed. It is just a simple wire connected to one of the orange connectors you got when you ordered your cable
Old Sep 1, 2011 | 08:31 PM
No special cable huh.. Well i do have the orange connectors
Old Sep 4, 2011 | 03:09 AM
Ok, so.. Figured out the problem. Me and a friend went thru the entire wiring to see if maybe a ground was off or something wasnt right.. Turned out to be that the LC1 readout in the efilive was reading in Lambda. Had to hook up the Innovate LM software and go thur the process of changing that and resetting the LC1 interface. After doing all that I hooked up the serial cable to my V2 and it worked, AFR was all correct. So if anyone else has this problem, its in the LM software and you have to change the settings. Pretty simple
Idryfly5
Sep 2, 2022 08:55 PM
murderedSS
27
Oct 12, 2015 11:13 AM
TAPyvehc93
Sep 14, 2015 01:22 PM
dselby25
Sep 11, 2015 05:03 AM
Boyes50
Sep 8, 2015 12:06 PM
