V2 to LC1 issue
Old Aug 31, 2011 | 11:36 PM
2007chevy5.3l's Avatar
Default V2 to LC1 issue
Have a problem with logging my LC1 with Efilive V2. For some reason my AFR reading is missing the first number example. instead of it reading 15.11 it reads 5.11 in my PID list.. Yes, my V2 is current with the latest download. I hooked up the serial cable provided with the gauge kit to the logworks on my computer and check the fuel readout and it was set for Gasoline. Idk what the deal is... Heard it could be a faulty LC1 but both my truck and a friends reads the same. Kinda weird. Any help?
Attached a log-
File Type: efi
Old Sep 1, 2011 | 04:44 AM
Gadgetized's Avatar
That is actually showing to be at 5.31 AFR. What does it show when you do a free air calibration? I wouldn't even try logging with the V2 at this point, just go through the Innovate software. Is it a new sensor?
Old Sep 1, 2011 | 05:00 AM
smokeshow's Avatar
Mod with training wheels
Did you make the little LED/pushbutton switch to calibrate it? It needs a basis for comparison for amount of ambient oxygen. Probably showing max voltage, which is minimum AFR reading.
Old Sep 1, 2011 | 06:15 AM
No its not a new sensor. I calibrated it a couple weeks ago but I will go ahead and do it again. I did make the little LED/pushbutton switch also.. I just thought it was weird cause on the gauge it reads 15.xx but the PID shows 5.xx.
Old Sep 1, 2011 | 07:59 AM
Gadgetized's Avatar
What does the AFR read on the FlashScan? I don't have mine in front of me but I think it is: F1>F2>F1>F4
Old Sep 1, 2011 | 12:04 PM
BlackGMC's Avatar
Resident Retard
It means it is broke. Currently mine is doing the same thing. The analog portion works fine however something on the serial side of the controler is broke. Same thing happened to me before. Luckily i have a 2nd lc1 sitting on the shelf i just gotta find time to install it
Old Sep 1, 2011 | 12:15 PM
Yeah
Im tried just about everything and thats pretty much the road thats its leading me down. What a bummer
Old Sep 1, 2011 | 12:19 PM
This what you mean?
Old Sep 1, 2011 | 04:31 PM
Gadgetized's Avatar
Yeah, that's what I meant. Man that stinks if the unit is bad.
Old Sep 1, 2011 | 04:43 PM
Tell me about it... Im wanting to work on my VE table and was wanting to do it this weekend.
