Unusual starting problem
Old Jul 4, 2013 | 07:18 PM
whippled 8.1l build's Avatar
was thinking crank position but i had the same problem with my 00 silverado 4.8 and it was my throttle position
Old Jul 7, 2013 | 02:14 PM
TrickTurbo's Avatar
Truck Sponsor
Ok did some check.
Being an 03 no TPS sensor it's all in one unit.
Fuel psi does drop after a few min. After turbkng truck off.
Down to 20psi. Thought " I got it now" NOPE
turn the key on let psi come up. To 60.
Still has starting troubles.
Thought maybe tbody sticking. Nope blade moves nice and easy.
Can see it cycling while key is turned to the on position.
Any other ideas? I'm lost
Waiting to get me a laptop to plug in and see if there are any codes that are there. Just not the ones that throw a light.
Old Jul 7, 2013 | 02:33 PM
AKlowriderZ71's Avatar
11 Second Hall Moniter
It's the fuel pump. Be sure you replace the fuel filter at the same time.
Old Jul 7, 2013 | 02:36 PM
TrickTurbo's Avatar
Truck Sponsor
Wouldn't that show up as no or low psi?
I have 60psi while cranking.
Old Jul 7, 2013 | 11:00 PM
fastjweb's Avatar
Rick, my parents 02 with the 4.8, did the same thing. I checked fuel pressure when i was home to AZ and it was fine, but no start. They had it towed, turned out it was the fuel pump. It was intermittent as well. I also had a buddy in high school that had a 95 camaro, and his car did the same thing, turned out to be the fuel pump. If it has the stock FPR, you can pull the vaccum line and see if fuel comes out. I had a 01 4.8 that was intermittent, and would crank forever, it was the stock fpr.
Old Jul 8, 2013 | 05:30 PM
Byrdman11's Avatar
Rick the truck just spin and no start? Also try to open the throttle during start the truck to see if that help it start.
Old Jul 11, 2013 | 02:53 PM
TrickTurbo's Avatar
Truck Sponsor
I swapped the regulator part out.
So far it fired right up and hold psi.
I am still trying to see why it wouldn't start before.
It had 58psi but during cranking start issues.
ferrellrooster
Mar 6, 2025 03:22 PM
treylittlefield
Jan 24, 2016 07:38 PM
chevy6.0fan
Aug 20, 2015 07:10 PM
WarbirdLS1
Aug 8, 2015 10:53 PM
Mossyoakglock
Jul 17, 2015 08:30 AM
