UEGO Wideband AFR Controller... HELP!
Old Feb 8, 2009 | 05:10 PM
$nake Charmer's Avatar
Default UEGO Wideband AFR Controller... HELP!
i have recently purchased a wideband gauge and sensor... in the instructions it says to mount the sensor before the cat(s) for a more accurated reading... but i only have one sensor, and i have 2 cats before the Y. Please help... do i only run one sensor comming from one exhaust mannifold, or do i put the sensor after the Y, Which would be after the cats, but it would get both exhaust manifolds??? PLEASE HELP...
__________________
Old Feb 8, 2009 | 05:51 PM
viciousknid's Avatar
Where's the Beef?
You have to weld in a Bung for the wideband sensor.
Here's a pic of mine. I had a bung welded in a few inches behind the front sensor and then swapped them around. Put the front sensor into the new bung and the wideband into the original bung.
Old Feb 8, 2009 | 06:08 PM
Where's the Beef?
and incase your not sure what an o2 bung is.
Old Feb 8, 2009 | 06:58 PM
ok i know what a bung is but where do i mount the wideband o2 sensor
Old Feb 8, 2009 | 06:59 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
Driver's side
Old Feb 8, 2009 | 08:40 PM
you mean behind the drivers side manifold... why the drivers side???
Old Feb 8, 2009 | 08:57 PM
Where's the Beef?
#7 cylinder will go lean first. it's the most accurate side to read from. You want it after just a few inches away from the Front o2 sensor that is already there.
Old Feb 9, 2009 | 03:13 PM
thanks guys... more than helpful...
SS94S10
Jan 3, 2019 01:57 PM
97_ek
Sep 23, 2015 09:16 PM
madmann26
Sep 6, 2015 04:19 PM
zblee
Aug 3, 2015 03:45 AM
slowlsx
Jul 13, 2015 04:18 AM
