U0101 code after motor swap
Old Feb 18, 2013 | 02:58 PM
carbongmc's Avatar
Default U0101 code after motor swap
So I hooked up the battery last week after about 10 months of it being off. Im getting a U0101 code (miscommunication with TCM) and also the Service Traction Control is on as well. I did some searches and found that some people get this with a low voltage battery, as mine was only at 10 volts when this happened. Got it fully charged, still doing both. I also dont have the small indicator light under what gear the truck is in either with this code coming up. Has anyone had this issue, or have I somehow fried my TCM and need to replace it. I cant crank the truck up like this (from what Ive seen online) as this problem wont let it start up. Any info is greatly wanted and appreciated on this right now.
Old Feb 18, 2013 | 03:39 PM
You need to get a scanner and see if you can establish communication with the pcm and tcm.. First thing I would start doing is going and checking each and every ground point on the block especially the grounds at the rear of the cylinder heads.
If those are solid then follow the trouble tree for the above code and you will find the culprit.
Old Feb 18, 2013 | 03:46 PM
carbongmc's Avatar
Trouble tree? Not a phrase Ive heard before....
The grounds "should be" good. Only difference in anything with the grounds to the motor, is that the ground going along the pass side valve cover next to the injectors, that bolts to the front of the pass side head, was bolted to the rear of the pass side head. Thats the only thing Ive done with the grounds at all. I dont see that being the issue really, but what do I know. lol
Old Feb 20, 2013 | 10:54 AM
carbongmc's Avatar
Bump, anybody got anything?
Old Feb 20, 2013 | 11:33 AM
smokeshow's Avatar
Mod with training wheels
Put a multimeter on pins 6 and 14 of the OBD2 port. Should give you 60 ohms. That will confirm data line continuity throughout the harness.
Old Feb 20, 2013 | 11:34 AM
smokeshow's Avatar
Actually...where you lengthened your harness to route under the intake, did you make sure to twist the data lines?
Old Feb 20, 2013 | 02:41 PM
carbongmc's Avatar
The only wires I lengthened were the 8 injector plugs, the evap plug, and the Alt plug. I never touched any other wires. That is why I cant see any of those being the issue, but I could be way off as well.
Old Mar 3, 2013 | 12:42 AM
updates?
OHsixLS3
Dec 27, 2016 09:30 AM
chevyl33
Aug 24, 2015 08:21 AM
lo&sloSierra
Jul 24, 2015 07:03 PM
GreyChevy
Jul 7, 2015 08:57 PM
Nimoryan
Jul 5, 2015 03:50 PM
