tunning and using a lc1 wideband?
Old Jul 5, 2009 | 11:18 AM
Dark Halo's Avatar
Default tunning and using a lc1 wideband?
Just wonder what you guys are setting you lc1 wide bands to with the log work software for analog 1 and 2. I have efilive and set it as per there recommendation but my reading just seem to be really far off
Old Jul 5, 2009 | 07:10 PM
Mort's Avatar
Wide Band AFR1 - LC-1 {CALC.AFR_LC11}
Mine is set at Expression:
AFR = ({EXT.AD1}*3) + 7.35
V = {EXT.AD1}
this setting seems to work fine for mine.
Old Jul 5, 2009 | 11:49 PM
Dark Halo's Avatar
I am looking for what you program the sensor controler to using the lm programer
Old Jul 6, 2009 | 07:11 PM
Mort's Avatar
I am pretty sure this is what I have programmed into the LC1 :
1.) Verify fuel setting is gasoline and set at 14.7
2.) Click on the analog output 1 tab
3.) Set as follows:
a. select the "air fuel ratio" button.
b. 1.000V = 10.00 a/f
c. 2.000V = 20.00 a/f
d. select "advanced' button
e. select "instant" sample rate
f. enter 0.00V at warmup
g. enter 5.00V at output error
h. press "OK"
i. press the "program button". This takes little time and the program button will be shaded.
j. You are done!
Is this the info you are looking for?
Old Jul 7, 2009 | 01:41 PM
Dark Halo's Avatar
yes, I have it programmed as so. I just did not know if anyone was using anything different.
SS94S10
Jan 3, 2019 01:57 PM
97_ek
Sep 23, 2015 09:16 PM
madmann26
Sep 6, 2015 04:19 PM
zblee
Aug 3, 2015 03:45 AM
slowlsx
Jul 13, 2015 04:18 AM
