tunning for injectors
Old Apr 11, 2009 | 12:18 PM
Dark Halo's Avatar
Default tunning for injectors
My current tune on my 02 is for 44# truck injectors if I swap to the car style 42# injectors will in need to retune?
Old Apr 11, 2009 | 12:47 PM
Wilde Racing's Avatar
How do I change this text
What are the specs of both sets of injectors? are they both rated at 3 bar or 4?
Old Apr 11, 2009 | 02:43 PM
Dark Halo's Avatar
not sure I have not ordered the other injectors, Im am tring to sell the 8.1 marine injectors first. The ones I was looking at were the racetronix 42# and it does not say what bar on thunders website
Old Apr 11, 2009 | 03:13 PM
which 42? most racetronix are rated at 3 bar...
Old Apr 11, 2009 | 04:23 PM
Dark Halo's Avatar
http://thunderracing.com/catalog/?ac...oduct&pid=3645
Old Apr 11, 2009 | 04:46 PM
Part Number 01D030B (Lucas old 5208009, Lucas New 621031, Delphi old D3181AA)
All tests run with n-Heptane @ 20oC (+/-1oC), 3.0 Bar (+/-0.01 Bar), 14VDC (+/-0.05VDC), saturated driver with RC cutoff
Static Flow Rate: 42.29 lb/hr (+/-4%)
Dynamic Flow @ 2.5ms PW @ 100Hz: 9.96 mg/pulse (+/-6%)
Coil Resistance: 15.9 Ohms (+/-0.35 Ohms) (This high-impedance injector will work with all factory ECM/PCM injector drivers)
Spray Pattern: Tri-Cone
Physical Dimensions: EV1 Body Type
Connector: Minitimer (Bosch EV1)
Factory fitted with Viton upper and lower o-rings.
Grease supplied to lubricate o-rings prior to installation.
Old Apr 12, 2009 | 01:27 AM
Dark Halo's Avatar
yea same injectors
Old Apr 12, 2009 | 08:49 AM
now you need to find the specs on the other injector..
Old Apr 12, 2009 | 10:06 AM
Dark Halo's Avatar
Brands: Delphi
Manufacturers: Delphi Injectors
Model 17113739
Categories: High Impedance
Retail P/N: 135-INJ-17113739-8
Manufacturer P/N: 17113739
Static Flow lb/hr: 37.95
Static Flow cc/min: 398
Dynamic Flow (mg/pulse): .748
Dynamic Flow Tolerance /-%: 5%
Connector Type: Multec 2 (Delphi)
Weight (non-shipping): .05 lbs
Old Apr 12, 2009 | 10:10 AM
mred's Avatar
sense you guys are talking about injectors. through a tune can you apply more fuel? "stock"
my truck already has a tune in it and im thinking i could have my tuner apply more fuel,through out the whole rpm range.
thanks
Ed
