tunning help!!!!!
Old May 19, 2010 | 12:12 AM
53RUSSELL's Avatar
Default tunning help!!!!!
I just did engine swap from a 5.3 to 5.7. I'm having issue with costom 5.7 tune i made up. The truck fire and pops to grand and then stombles intill it dies. If you feather the trottle it will run longer but just stombles. So for kick I load my turbo 5.3 tune and fire right up with no issues but did lean because not the right tune. So here is the tune i made up. Here is the specs for the motor. 2000 LS1 with LS6 cam, 9.2cr with 60lb injectors, 317 heads, and t70 front mounted turbo. Thanks for the help guys.
File Type: tun
Old May 19, 2010 | 05:22 PM
MikeGyver's Avatar
I can't read the tune, did you rescale the 5.7 tune for the 60 pounders? Was the 5.3 tune set up for the 60s?
Old May 20, 2010 | 01:22 AM
53RUSSELL's Avatar
I had all the same stuff install in my 5.3. The only thing the changed was the new 5.7. I for got to change the 1bar settings to 2bar settings on the the ls1 tune thats why it wouldn't start.
Z284thgen
13
Jun 3, 2006 08:14 PM
macs406
Jun 1, 2006 09:05 PM
v8
Feb 8, 2004 08:53 PM
rgvsierra
Jan 10, 2003 02:44 PM
