tunning 8.1 Marine
Old Aug 13, 2008 | 10:03 PM
53RUSSELL's Avatar
Default tunning 8.1 Marine
I'm tiring to get my long fuel trim in to be -4 to +4. I tried adjust the injector voltage to correct my fuel trims but I think I’m doing something wrong so if you guys can help. Here is snap shop of my injector flow, voltage table and log file. Thanks for the help.
File Type: efi
Old Aug 13, 2008 | 10:12 PM
charcold-bowtie's Avatar
I dont think you need to be messing with the voltages. DO you have a wideband on it. Set the IFR to appr values, set up OLSD and fix the Ve using BENS factors is what I did.
Old Aug 13, 2008 | 11:03 PM
53RUSSELL's Avatar
Whats is IFR?
Old Aug 13, 2008 | 11:04 PM
its in your screenshot. (injector flow rate)
Old Aug 13, 2008 | 11:16 PM
53RUSSELL's Avatar
Sorry been up 4:00am and now 9:16pm. I know that answer brain just working slow.
Old Aug 13, 2008 | 11:45 PM
im pretty sure your boosted. Get a wideband if you dont have one. Im sure ya know kbracing carries them.
then proceed. Leave the pulse width alone.
Old Aug 13, 2008 | 11:50 PM
53RUSSELL's Avatar
I have one already and now was lookong through MY tunes to find the stock injector voltage table. So far no luck.
Old Aug 13, 2008 | 11:59 PM
jump on holden crazy .com I think they should have one. Set that crap to stock and run on other stuff.
Old Aug 14, 2008 | 01:35 AM
454SuperSport's Avatar
IFR should be 43.82 across the board, and i started a thread not too long ago about the voltage offset table. the values i listed have been working great in my truck.
Old Aug 14, 2008 | 07:57 AM
53RUSSELL's Avatar
Here is the formal to get your injector size. 43.82 X sqrt(66/58)
43.82 is what the injector flows at 58psi (fuel regular is set at)
My fuel regulator is set at 66psi. Or you can use this excel file.
I had my injector set before at 43.82 and my ve table coming in very high for mods.
File Type: zip
