tuning for vacuum mod
I figure i'll be getting a nelson tune soon and he'll know what to do but i was just curious as to what parameters need to be tuned now that the tranny has the vacuum mod. Did a search and only found that tc lockup and shift points(short thread) need to be tuned. Surely something else needs to be tuned. Anyone know? Thanks,
Bryan
Bryan
I haven't had any problems with vac modded 60's. 80's, on the other hand, sometimes act weird after a vac mod conversion. They shift when they want to not when the ecm commands the shift at a given rpm/mph criteria. I've asked Gil or Glen @ transgo and no one is 100% sure why.
on a 60e you don't have to worry about shift firmness and shift speed, that's all controlled by the VM. The only parameters that make a difference is the shift vs. vehicle speed vs. rpms and the TCC tables.
The're also controlled via vm on the 80e, but something is causing weird things to happen. Shift timing/solenoid firing is still controlled via ecm and that's about it. The experts (aka the people who make the vm and shift kit)
can't pinpoint what's going on with the 80's.
ARC
57
Feb 21, 2022 10:54 AM
