Tuning trans pressures
Old Feb 18, 2009 | 08:51 PM
charcold-bowtie's Avatar
Default Tuning trans pressures
My built 80e seems to still shift too hard. Actually seems really random at times with its shift firmness. I keep reducin the base pressure on the shift. THe force motor table is stock also. Im sure it has a valve body kit in it as well. Is there any thing else I can do to lower the pressures. Ive gotten a bit worried there too low, I assume a good shift means that I shouldnt worry too mucha about the values though.. The shift is still firm though. THoughts?
Heres a tune, DO not take it as a whole. But it does have my trans segment.
File Type: tun
Old Feb 18, 2009 | 09:11 PM
thunder550's Avatar
High on diesel fumes
**nevermind**
Old Feb 18, 2009 | 09:12 PM
nonnieselman's Avatar
What about adding a lil torque management? that should help some even tho its Vac Moded.
Old Feb 18, 2009 | 11:18 PM
Thats why its so hard!? lol I had a EPC put into it. electronic pressure control.
That vac regulator had problems to say the least. I had tranny oil all the way into the intake from that vac line also.....
ANyone else? I thought of TM, but I dont like the idea of cutting the powere down to shift.
Old Feb 18, 2009 | 11:23 PM
thunder550's Avatar
Ah ok I forgot that you ditched the vac mod, my bad
Old Feb 18, 2009 | 11:29 PM
ha, thats what i did on mine.. had to keep the 1-2 from spinning the drag radials at the track so i put 10% TM in.. it did the trick. i mean come on, you have a 80E now.
Old Feb 18, 2009 | 11:33 PM
90mph chirps cant be good for anything. guess I will keep lowering it a bit. look at the very end of that log. Watch mph.
File Type: efi
Old Feb 18, 2009 | 11:39 PM
i wouldnt lower the pressure too much..
Old Feb 18, 2009 | 11:46 PM
Well I feel I will bo ok but that what Im asking. Its still a firm shift, I guess from the drilled valve body? But as long as its a good shift am I ok?
Old Feb 19, 2009 | 07:03 PM
Mort's Avatar
My Force Motor Current table {D3801} is identical to yours and stock AFAIK.
My Base Pressure 1 -> 2 Shift {D0701} is quite a bit lower than yours. I lowered my Normal column by 6 from 160 NM to the bottom of the column. I have been running these for over a year and my 1 -> 2 is still firm at times.
0 - 0
20 - 0
40 - 0
60 - 0
80 - 0
100 - 0
120 - 0
140 - 0
160 - 0 (was 3 I think)
180 - 0 (was 6 and subtracted -6 from here down)
200 - 14
220 - 34
240 - 55
260 - 69
280 - 90
300 - 110
320 - 138
340 - 165
360 - 186
380 - 207
400 - 227
420 - 241
440 - 255
460 - 269
480 - 283
500 - 296
520 - 310
540 - 324
560 - 338
580 - 352
600 - 365
620 - 386
640 - 400
