Tuning for Tires
After upsizing my tires from 265-75-r16 to 285-75-r16 which is a 2inch increase in diameter and 18bs per tire, Im seeing more light throttle knock retard. Ive adjusted the speed and shift points to compensate for the larger diameter tire. However Im still encountering more light throttle knock retard. The additional weight and inertia appears to be causing this. There must be something I can do to fix this perhaps VE, spark or fueling.
Please advise!!!!
Please advise!!!!
You should not have increased diameter with that tire all you did was make it wider. The first number has to do with width not diameter. That is not a big difference either. Are you showing any codes? Get a tune from Jesse that might help!
going from a 265/75 to a 285/75, you will increase about .5 inch and width. It does have an effect on the height. Go to a tire conversion and just mess around with the first number and you will see what i mean.
Sounds like either riching it up a little or taking a couple degrees of timing out will solve the problem. But if it is less than 1 degree kr, I wouldn't worry about it. Try another tank of gas and just make sure that isn't it.
The tire diameter will change with the width if the second # stays the same.
1st # = width in mm
2nd #= side wall height referenced in percentage of width
in other words the sidewall is 75% of the width - 285mm
brands differ in size slightly due to differences way of measuring and construction.
1st # = width in mm
From 265/75-16 to 285/75-16 is exactly a 1.2" increase in diameter, from 31.6" to 32.8". However, like mjhoward already said, sizes vary between manufacturers, and even between tires within a manfacturer, so you should measure to make sure.
Can't speak to the knock issue.
Please advise!!!!
Please advise!!!!
16" diameter wheel numbers+ tire size.
103.14" vs 99.43"
Originally Posted by moregrip
when you say you've "adjusted the speed and shift points to compensate" for the change, what did you do exactly?
Any thoughts?
