Tuning out KR???
Old Dec 18, 2005 | 08:46 PM
TURBHOE's Avatar
cot?? cat over temp yes its disabled
Old Dec 18, 2005 | 08:56 PM
67SS509's Avatar
10 Second Truck Club
Best answer now is a wideband and if it's under 13 to 1 AFR turn some or most of the kr off. You will hear any knock bad enough to damage the engine.
Old Dec 18, 2005 | 09:04 PM
TURBHOE's Avatar
my stock O2's are hitting between 855 and 900 on the data log but at about 100mph is where it starts.
Old Dec 18, 2005 | 10:38 PM
Flyer's Avatar
The stok o2's should be closer to 880, not going below 870 much at all, and absolutely not any further than 860.
The higher load and sustaining the higher rpms will cause it to go slightly leaner. I would richen it up a little and see if it goes away.
Old Dec 19, 2005 | 01:35 AM
chrisj6's Avatar
hey 12sec5.3, if you have the stock injectors in a 99 you have 19#ers my friend. Even smaller than you thought Thats why their maxing out with your mods, mine are too, but for the moment I have to live with em (gotta pay for my wideband first)
Old Dec 19, 2005 | 03:49 AM
Wilde Racing's Avatar
How do I change this text
Originally Posted by 67SS509
That's the way false KR comes on. Have you turned your COT off yet?
COT enabled will not make it any leaner. It could make it richer in the closed loop Command A/F ratio. in open loop the ECM takes what ever is richest , cot a/f or PE a/f. more fuel = cooler cats
Old Dec 19, 2005 | 05:48 PM
12sec.5.3's Avatar
I'm currently using the injectors that came with the 6.0 HO. But I hear they are 24lbs also.
D3moN plz
19
Dec 9, 2015 11:14 PM
06 4.8
Aug 21, 2015 11:33 PM
JFortner5
Aug 20, 2015 06:13 PM
Ls3silverado
Jul 31, 2015 04:22 PM
oharajo
Jul 18, 2015 09:24 PM
