tuning for higher stall torque converter
Old Aug 29, 2006 | 12:31 PM
silver-mod-o's Avatar
Hunt&Fisherator
Default tuning for higher stall torque converter
I'll be adding my 3000 stall converter either this weekend or next. I dont have it currently included in my tune. What all needs to change in the tune for the converter??? lock up speed? I dont really know.
will it hurt to run it without it in the tune for a while? I dont want to send it back for a re-tune right now... probably ever, I will be getting it dyno tuned before too long anyway.
Old Aug 29, 2006 | 12:45 PM
moes04silverado's Avatar
I had the same quesion for the Nelson guys, i was told that the lock speed would be the only thing that would be changed in the tune....
I have a Fuddle 3k that I need to install also, but have not had the time to get-r-done...
Old Aug 29, 2006 | 12:51 PM
Hunt&Fisherator
I'm putting in a PI Vig...
Old Aug 29, 2006 | 08:46 PM
chrisj6's Avatar
I raised the shiftpoints a hair on mine, maybe like 5-6%. Also you will want higher lockup speeds. Mine is only a 2500 stall though. I also set the shift lock to disabled.
Chris
Old Aug 30, 2006 | 10:18 AM
Hunt&Fisherator
anyone else? Where Yelo when ya need him LOL... I'm sure this has to be simple and I'm just over analyzing it.
Old Aug 30, 2006 | 11:36 AM
ZR1 DREAMING's Avatar
Ben, you'll be fine... we're doing the swap whether you like it or not. So get your panties unbunched
Old Aug 30, 2006 | 11:45 AM
Hunt&Fisherator
FAH-Q
Old Aug 30, 2006 | 12:03 PM
Yelo's Avatar
You'll be fine dude.....you'll want to raise your rev-limiter slightly to compensate for the looser stall (I've seen higher-stall TC's flare 100-200rpm at the shift sometimes), and firm up your shifts a little. There's not much else to "tune" in the tranny. Lock speed should be able to remain the same but you may need to play around with it to get it "right for you"
You can raise spark and lean PE out a little below the stall speed if you want to, it'll make the engine a little more free-reving below the stall speed when you stand on it
Old Aug 30, 2006 | 12:05 PM
Hunt&Fisherator
Thats pretty much what I figured man.. Thanks for the reassurance though. the rev-limiter is a good point though. Its a PI converter, supposedly they are pretty tight kinda like a Yank...
LCHEE
Oct 24, 2020 04:10 PM
TAPyvehc93
Jul 23, 2017 10:54 PM
BennyB
Aug 1, 2015 08:48 AM
KyleW707
Jul 29, 2015 08:17 AM
JordanH
Jul 14, 2015 03:46 PM
