Tuning for converter and Headers??
Old Apr 23, 2006 | 06:56 PM
ASkipper's Avatar
11 Second Club
Default Tuning for converter and Headers??
I am getting the Yank TT3200 converter and doug thorley headers with no cats put on this week.I need to know what to change in my tune for the converter and headers.Our local 1/4 mile is opening within the next few weeks,I want to be ready.
Old Apr 23, 2006 | 07:11 PM
02sierraz71_5.3's Avatar
tune trims and might want to increase tcc lockup pressure, if your removing the cats delete all SE codes for the rear 02's, no need to mess with sims then
Old Apr 23, 2006 | 07:20 PM
ASkipper's Avatar
11 Second Club
In what chart on HP Tuners can I increase TCC lockup pressure? Also should I tune what mph it locks up at?
Thanks for the help.
Old Apr 23, 2006 | 07:28 PM
Its under the tcc tab in the tranny window, I forget the exact name.
As far as what mph to lock the converter up at that is up to you and whatever cam youve got, my table is mostly stock except for bumping the speed up at low tps to avoid tcc lockup under 1100 rpm it puts alot of load on the engine with a bigger cam causing kr.
One thing you definately want to do though is to set the 100% tps column in the tcc lockup table to 256 as the stock table will lock the tc at 80 mph regardless.
Old Apr 25, 2006 | 07:44 PM
TURBHOE's Avatar
with my shift kit and tc install i didn't have to change i put everything thing stock. but if you don't have a big cam i would lower your lock up speeds just a little for around town driving. mine locks up about 35 mph with light throttle but if i have to push it down very far it will unlock for higher loads. but with ut a shift kit yeah you may need to raise the lock up pressure table.
so 02sierraz71_5.3 you say it will lock up anyway at 80 even if the tps is at 100%. i may have to look at that then what is the name of the table can you look? i would but i'm at work.
LCHEE
Oct 24, 2020 04:10 PM
chopperloco
Jul 10, 2016 10:45 PM
shawn96gmc
May 17, 2016 04:15 PM
GMCtrk
Jul 17, 2015 06:39 PM
