Tune and nitrous?
Old Apr 30, 2007 | 05:26 PM
03GMC's Avatar
Default Tune and nitrous?
So Im going to get the wait4me tune here pretty quick. Down the road Im going to add nitrous. Can he program the pcm to be ready for nitrous even though its not hooked up now? Or how would be the best way of going about this?
Old Apr 30, 2007 | 06:36 PM
Rhino79's Avatar
9 Second Club
Yes, timing will be a bit different but all else should remain the same.
Old Apr 30, 2007 | 11:14 PM
03GMC's Avatar
So he can tune for nitrous and change timing for driving around daily and then hitting the bottle at the track?
Old Apr 30, 2007 | 11:39 PM
Derek @ EDO's Avatar
FormerVendor
what shot are you going with?
whats your mods?
Old May 1, 2007 | 12:17 AM
99Silverado5.3's Avatar
You will need a timing tuner to be able to change the timing n/a to nitrous. He should be able to tune for the nitrous, but your n/a times will be a little slower vs. an all motor tune without the timing tuner. It will be allright though to have a nitrous tune and drive it everyday. Just tell him your mods and what shot you plan to run and you will be ok.
Old May 1, 2007 | 12:58 AM
Kingpimp's Avatar
Couldn't the tuner setup two spark tables? Low octane and high octane. Once he gets a little knock while spraying, it should switch to the low octane spark tables.
Old May 1, 2007 | 02:38 AM
bluecajun5.3's Avatar
11 Second Truck Club
wait4me uses efi live. you could set up and external button just for the spray. so this way your basically getting the most out of you n/a tune and at the touch of a button, it switches to the nitrous tune. that's how my tuner has his car setup.
Old May 1, 2007 | 06:34 AM
Rhino79's Avatar
9 Second Club
Correct, COS5 is the nitrous system. Your activation switch wires into the pcm, and once you arm it you'll be running with less timing. I think that you can only run COS5 on 2002 operating systems though, unless they recently added it for newer models.
Old Dec 17, 2007 | 01:10 PM
zmonsterjb's Avatar
anyone know where I can get a nitrous kit for a 2002 5.3 truck?
X_Racing1
21
Mar 30, 2016 02:37 PM
southernsmoker
Aug 31, 2015 03:09 PM
slowlsx
Aug 13, 2015 08:28 PM
slowlsx
Aug 10, 2015 05:33 PM
