Truck wont start after mail order tune throwing P1631
Old Dec 29, 2007 | 03:38 PM
maddboost's Avatar
Default Truck wont start after mail order tune throwing P1631
I recently ordered a replacement PCM from Nelson Performance to tune out P0420 and P0430 emissions codes after installing a set of long tube headers on my 2003 Silverado SS. I installed the new PCM today and the truck will not start, it cranks but no ignition and throws code "P1631 Theft Deterrent Password Incorrect". When I swap my stock PCM back in it starts right up.
Anyone have any ideas if this is something I can fix or was the PCM programmed incorrectly?
Old Dec 29, 2007 | 03:53 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
There is a procedure you have to do to reset the the passkey, I forget how it is done but it is very simple. I think you can find the procedure on his web site.
Old Dec 29, 2007 | 03:57 PM
Mort's Avatar
You need to reset the security code in VATS.
1. Turn the key on to start the engine, then release the key to the ON position.
2. The security light will flash for 10 minutes then go off.
3. Turn key OFF after security light has stopped flashing.
4. Leave the key off for 30 seconds or so. Not sure if you have to wait but it won't hurt. Repeat steps 1 to 3 for 2 more times for a total of 3 attempts. The vehicle should start on the 4th attempt. This procedure takes at least 30 minutes. The battery should be fully charged and deliver more than 10 volts.
These instructions should have been included with your PCM from Nelson!
Old Dec 29, 2007 | 04:18 PM
maddboost's Avatar
Ill have to try that tomorrow its too cold now about 15 degrees here and im working in the driveway. I looked through all the paperwork and didnt see this hopefully it will work. Ill check back if it doesnt.
Thanks
Phil
Old Dec 29, 2007 | 07:37 PM
trever1t's Avatar
Yes, that's it. I did all that back in the days when I had a mail order tune. One time it didn't work, I disconnected the PCM pins and then reconnected...started right up.
Old Dec 29, 2007 | 08:03 PM
Wheatley's Avatar
Truck Sponsor
follow the security relearn and it will start at the 4th attempt
Old Dec 30, 2007 | 05:46 PM
maddboost's Avatar
Well the 3 cycles worked once I disconnected the negative terminal on the battery and reconnected it. Now its time to put some miles on it before going to emissions tomorrow. It just started snowing here again.
Old Dec 30, 2007 | 07:34 PM
trever1t's Avatar
Good deal and good luck!
Old Dec 31, 2007 | 09:35 AM
Melissa@NelsonPerformance's Avatar
FormerVendor
Great to know everything went well!
Melissa
Old Dec 31, 2007 | 11:16 AM
Mort's Avatar
Good to hear you got it working. Not sure why you had to disconnect the battery but maybe to clear any codes previously set.
It is snowing now and it is supposed to snow here for the next 3 days.
