truck will not shift at wot
Old Jul 31, 2012 | 04:23 PM
  #21
nonnieselman's Avatar
Yea, it depends on what PID he logs as to what TPS value you will see
Old Jul 31, 2012 | 04:41 PM
  #22
Gadgetized's Avatar
Try this at your own risk, that should get you shifting in the 5200 RPM range.
A couple things, you are pretty agressive with removing timing under boost. Why do you want to shift at such a low RPM? If you are using the cam in your sig, that thing is begging for RPM's.
File Type: tun
Old Jul 31, 2012 | 04:57 PM
  #23
Prolly cause his injectors are maxed
Old Jul 31, 2012 | 05:10 PM
  #24
Gadgetized's Avatar
Oh yeah, that's right.
Old Jul 31, 2012 | 05:15 PM
  #25
smokeshow's Avatar
Mod with training wheels
Nothing wrong with that when you're learning
Old Jul 31, 2012 | 05:51 PM
  #26
AndysC3's Avatar
I have the 100% throttle set to 25 so that it will command the shift at 5200rpm. And injectors are maxed at 5300-5400. Once I get it to shift I may move the shift up as long as I have injector. Somethings up with my fuel system. Just installed a new FPR and now it wont hold fuel pressure with the key on and is at 54psi with the engine on and vac line removed. This is the one I got
Amazon.com: Delphi FP10021 Fuel Injection Pressure Regulator: Automotive Amazon.com: Delphi FP10021 Fuel Injection Pressure Regulator: Automotive
Fuel filter was also replaced about 8 months ago.
Old Jul 31, 2012 | 07:18 PM
  #27
1Bear's Avatar
Originally Posted by smokeshow
That's a trait of DBW. They are open at idle 15% or so...flooring it only adds 85% to open the throttle all the way. Log throttle position to see actual value, not accelerator pedal position.
I agree, this is common in most DBW GM trucks, yet while I haven’t even taken a peek at Andy’s tune, something that is common to the factory tune on the C³’s and its DBW system is a commanded ETC Limit vs RPM vs % Max Available Torque setting of 83%. I don’t know why GM chose to do this on these early systems and changing the tune closer to 100% setting doesn’t seem to have ill effects, to the contrary actually. I would be careful though, as in some cases people have REP problems when going beyond 98% or so depending on the individual throttle body, if the TPS believes it’s gone past 100%.
Old Jul 31, 2012 | 07:45 PM
  #28
AndysC3's Avatar
the 101 log I was not at full throttle until frame 1160. At wot it will go to 100% then drop to 99.6%.
Old Jul 31, 2012 | 08:22 PM
  #29
Gadgetized's Avatar
I had initially looked at log 102, and didn't see it going far enough to go into WOT. When I opened log 101, I could see it opening properly.
Old Aug 3, 2012 | 06:21 AM
  #30
03sierraslt's Avatar
So have you figured anything out?
