Truck stalls after CAI install... HELP!
Old Jun 3, 2009 | 07:11 AM
ChevyTruck's Avatar
something else
Exclamation Truck stalls after CAI install... HELP!
I did a K&N CAI install on 04 GMC 5.3, after completing the install we reved the motor up just to hear the differance and it stalled. It only does it if it goes higher then 4K in the revs. Any ideas what it could be? I have never heard or seen this happen before. We doubled checked the MAF.
Old Jun 3, 2009 | 07:29 AM
shupe's Avatar
I'd venture to say its abuse management or something similar within the tune. I don't have EFIlive on pc I'm on but i'm willing to bet its a non issue.
Have you tried to rev higher than 4k prior to the install?
Old Jun 3, 2009 | 07:32 AM
buzzkillwill's Avatar
Are you getting a CEL light??
Any hesitation or rough idle??
Old Jun 3, 2009 | 08:16 AM
8.1 HD's Avatar
Take it out of Park to rev it...abuse management/rev limiter
Old Jun 3, 2009 | 08:57 AM
hirdlej's Avatar
+1, it'll cut off after 4K RPM's in nuetral or park. How does it go in gear? Do you get a reduced engine power? If so, there are some other parameters that need adjusting but I highly doubt you'd need to on a stock truck.
Old Jun 3, 2009 | 09:10 AM
ChevyTruck's Avatar
something else
I'll have to get him to give it a try it in nuetral.
No SES light. It's fine to drive no problems, don't know about getting on it.
Stock tune as of now.
Old Jun 3, 2009 | 10:19 AM
dlt76028's Avatar
sounds like a leak to me. check all the rubber couplers especially by the MAF
Old Jun 3, 2009 | 11:15 AM
ChevyTruck's Avatar
something else
Joe did you ever have a problems with the intake? It's the one that I got from you.
Old Jun 3, 2009 | 12:55 PM
banker099's Avatar
+1! sounds like a maf related problem
Old Jun 3, 2009 | 01:15 PM
hirdlej's Avatar
I never had problems with it. Then again, I don't use my MAF. I've always run speed density. IM me tonight on messenger and I'll see if I can help you out to make sure you have everything hooked up right. Have the guy drive it though and **** can it when in gear first to make sure he's not just bouncing on the rev limiter in park.
