truck idles wayy down when stoping
Old Sep 16, 2008 | 06:08 PM
foff667's Avatar
LS1TECH Sponsor
Originally Posted by BlackGMC
add a little bit to the throttle cracker table, except for the 0mph column... Adding too much to that table and you will have cruise control, to little and it will stumble/stall
There are no throttle cracker/follower tables in NBS trucks.
Old Sep 16, 2008 | 06:21 PM
BlackGMC's Avatar
Resident Retard
Oh I never seen a tune from NNBS truck, I assumed there was, is there equivalent table?
Old Sep 16, 2008 | 06:44 PM
foff667's Avatar
LS1TECH Sponsor
Nope, not a straight equivalent at least, most just use the airflow tables to adjust the idle recovery currently. You could also probably use the minimum idle speed desired table since it can be set via mph rather than ECT. I know HP Tuners has this table under engine-idle rpm.
Old Sep 16, 2008 | 07:11 PM
dc_justin's Avatar
Hello Dave
The throttle cracker table is essentially rolled up into the desired airflow table as the Minimum Idle Airflow table. Columns are gears 1-6, N, R, P and row value is RPM from 200-8000.
Justin
Old Sep 19, 2008 | 05:19 PM
LS1FREEK's Avatar
13 Second Truck Club
my truck does the same thing every time I reflash the pcm... If i drive it around town for a couple of hours it learns to control the idle all by its self. If I move the complete idle airflow table up about 5% it seems to help a little, at least then it doesn't die. How long has this been going on?
wrb002
Aug 31, 2015 12:00 PM
Mossyoakglock
Jul 17, 2015 08:30 AM
black6spdz
Jul 16, 2015 01:32 AM
GreyChevy
Jul 7, 2015 08:57 PM
Breitling
Jul 6, 2015 06:39 PM
