Higher altitudes
Old Sep 14, 2008 | 09:52 AM
da_vato's Avatar
Default Higher altitudes
I went from a lower altittude around 1000 to a higher around 7000. What do you have to do to tune for higher altitudes? Pull timing, add timing? I had to pull some fuel already cause the exhaust was real rich. Thanks for the help
Old Sep 14, 2008 | 10:19 AM
tarinitup's Avatar
9 Second Truck Club
If you are running a maf it should self adjust but speed density may need some adjustment.
Old Sep 14, 2008 | 05:20 PM
da_vato's Avatar
**speed density**
So do I have to redo my VE?
Old Sep 14, 2008 | 05:29 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
even running SD you should be fine if in closed loop, right?
Old Sep 14, 2008 | 08:30 PM
sprayed8's Avatar
I would say you're right about that. Maybe it would be useful to reset your fuel trims so they will learn at altitude faster?
Old Sep 14, 2008 | 10:03 PM
stock48's Avatar
9 Second Truck Club
Are you NA, or boosted?
Old Sep 14, 2008 | 10:22 PM
da_vato's Avatar
boosted
Old Sep 15, 2008 | 03:22 AM
stock48's Avatar
9 Second Truck Club
boosted
If you are boosted then you are going to need to add 3~4 psi of boost to burn close to the same fuel as sea level. When I first got to COS (7000' on the north end of town) I was running 6psi my truck up here at 6psi went pig rich(clear off the scale) I ended up having to run 10psi to get the WOT AFR back in line, and had to mess with the PE KPA due to the extra lag, and lower vacuume. You should notice a few HG less vacuume @7000'. Your boost to KPA ratio is going to be off at altitude. At 7000' I have 76KPA ambient vs ~100KPA @ near sealevel.
Old Sep 15, 2008 | 11:33 PM
WJ MARK's Avatar
also how much slower is your truck up here????? sucks huh, LOL. J/K I feel your pain.
Old Sep 17, 2008 | 09:02 AM
da_vato's Avatar
heck yea it sucks I used to do some raunchy burn outs now I cant roast tires at all. Plus the exhaust is hella rich.
