Trouble Codes - Any ideas?
Old Apr 5, 2008 | 11:28 PM
foxySS's Avatar
Default Trouble Codes - Any ideas?
My brothers truck threw a bunch of codes the other day. Anybody have any ideas what these mean or why they might be happening?
Diagnostic Trouble Codes
P0120 "Throttle Position (TP) Sensor 1 Circuit" EPA ($10) "Powertrain Control Module (PCM)"
P0220 "Throttle Position (TP) Sensor 2 Circuit" EPA ($10) "Powertrain Control Module (PCM)"
P1516 "Throttle Actuator Control (TAC) Module Throttle Actuator Position Performance" EPA ($10) "Powertrain Control Module (PCM)"
P2108 "Throttle Actuator Control (TAC) Module Performance" EPA ($10) "Powertrain Control Module (PCM)"
U0107 "Lost Communication With Throttle Actuator Control Module " EPA ($10) "Powertrain Control Module (PCM)"
P0120 "Throttle Position (TP) Sensor 1 Circuit" H ($10) "Powertrain Control Module (PCM)"
P0220 "Throttle Position (TP) Sensor 2 Circuit" H ($10) "Powertrain Control Module (PCM)"
P1516 "Throttle Actuator Control (TAC) Module Throttle Actuator Position Performance" H ($10) "Powertrain Control Module (PCM)"
P2108 "Throttle Actuator Control (TAC) Module Performance" H ($10) "Powertrain Control Module (PCM)"
U0107 "Lost Communication With Throttle Actuator Control Module " H ($10) "Powertrain Control Module (PCM)"
C0281 "Stoplamp Switch Circuit" H ($29) "Electronic Brake Control Module (EBCM)"
C0298 "Powertrain Control Malfunction" H ($29) "Electronic Brake Control Module (EBCM)"
U1000 "Class 2 Data Link" H ($40) "Body Control Module (BCM) or Dash Integration Module (DIM)"
U1000 "Class 2 Data Link" HC ($89) "Digital Radio Receiver (DRR)"
Old Apr 6, 2008 | 12:00 AM
chevytruckguy's Avatar
I had a u1000 code come up when I cut a a wire in the big loom on the drivers side firewall. Its near the steering shaft. You might have a plug loose or disconnected judging by all the codes you have set.
blowngmc
32
Oct 12, 2017 11:59 AM
Tydriver
45
Oct 23, 2015 09:19 PM
MA$TER_E
Sep 9, 2015 03:14 PM
Pimpinpete
Sep 8, 2015 07:39 PM
muncie21
Sep 7, 2015 09:55 PM
