trouble code help me out!!
Old Feb 23, 2008 | 02:23 PM
WJ MARK's Avatar
Tried un hooking fans completely and didn't solve anything. Also installed another pcm with no luck either. I guess I do need to go back over everything under the truck.
Old Feb 23, 2008 | 06:10 PM
Mort's Avatar
Maybe give Allan a buzz. Maybe there is a small glitch in the PCM or retune he sent you? But I guess if you tried another PCM it has a older tune in it. If both PCMs have been flashed to the same tune then perhaps it is in the tune.
Old Feb 24, 2008 | 09:10 AM
WJ MARK's Avatar
The thing is It started acting up before I even loaded in the new tune. I have a feeling there is a piched wire somewhere, plug wires going bad since they have almost 90,000 on them, or a bad ground. Just need to find out where the hell the problem is comming from.
Thanks for all your help Mort, This is getting very frustrating!!
Old Feb 24, 2008 | 09:41 AM
Mort's Avatar
We used to check for bad plugs or plug wires by pulling the wires off one at a time with the engine running to see if there was a decrease in rpm and/or a rougher idle. If there is no change then that is likely a bad plug, wire, coil pack or coil pack connection. You can also spray a mist of water on each plug wire, coil pack to see if that grounds it out. This is best done in the dark so you can see the spark travel to the block. I have a set of plug wire pliers with a ground wire so that I don't get the 50000 volts running through me.
Old Feb 25, 2008 | 01:27 PM
WJ MARK's Avatar
I think I have a bad injector. Put a noid light on cyl. # 8 injector. Looks like an intermitten problem, when its running shitty the injector won't blink the light or somtimes will blink. when it running fine and smooth it blinks. I might try putting back in the stock injectors and see if it solves the problem.
Old Feb 25, 2008 | 05:21 PM
Mort's Avatar
Sometimes if you get a little rust or dirt in the system it finds its way to the back of the fuel rail and can plug up #8. Take it out and have a look. If it is you should be able to clean it up and flush the rail and be good to go. I have not had this problem yet (knock on wood) but have read a few posts.
Old Feb 25, 2008 | 06:05 PM
WJ MARK's Avatar
well added some BG to my gas and seems to have cleared it out. I think from the truck sitting for a couple weeks while waiting for a new tranny it got sticky and was hanging open. It ran worse at low rpm then high which tells me it was probably putting out the fire and on the upper end it was using the fuel. I ran the hell out it for 15 mins and let idle for a while, shut it off, stated back up. seems to be fine now. Thanks for all your help mort.! this probably explains why it worked fine before and ran like **** afterward.
Pimpinpete
43
Dec 22, 2017 08:13 AM
00loudchevy
Dec 3, 2015 05:54 PM
Avalanche2002
Nov 30, 2015 07:31 AM
bearden86
26
Nov 15, 2015 03:58 PM
kmcn47
Sep 17, 2015 01:12 AM
