Trouble Code=misfire cylinder #4.
Old Nov 17, 2011 | 07:51 PM
First Sergeant's Avatar
Default Trouble Code=misfire cylinder #4.
Guys the wife’s Tahoe 07, 5.3, LTZ 2WD has 234k miles on it and this code popped up. I changed the plug and it looked like it was ok. So the guy at NAPA said try the ignition coil, so I got just one. We never changed the plugs (doing that now) or done a tune up (while deployed the dealership informed her it was running fine.) My question is
1. Should I replace all 8 ignition coils and wires or should I
2. Swap the one and see if it clears the code up?
Mind you I just need it to get to Feb so I can get rid of it. (It has led a hard life and I want to send it out to pasture!)
Old Nov 17, 2011 | 08:02 PM
chevymec's Avatar
234k miles??? Dang lol. I would change all the plugs and wires first since its past time to do that. I would not replace all the coils, that is a waste of money, unless we are talking about a Ford mod motor.
Old Nov 17, 2011 | 09:59 PM
Plugs changed, ignition coil for number 8 changed and it's still misfiring WTF over? I'll tackle it in the morning thanks chevymec.
Old Nov 17, 2011 | 10:15 PM
chevymec's Avatar
Did you change the wires also?
Old Nov 18, 2011 | 07:58 AM
TXSZ66AVLANCHE's Avatar
When my 5.3 started going downhill @ 173k it started with misfire on cyl #1, month later misfire cyl #3 and it was not caused by the coil packs, plugs, wires, or injectors. The camshaft lobes were worn down on those cylinders.
Old Nov 18, 2011 | 02:13 PM
OK, guys it's threw, looks like TXSZ66 was right that cyl was full of oil this morning. Were in the process of plan B.
Old Nov 18, 2011 | 02:51 PM
Fastcount03's Avatar
NNBS are having problems with this, I have rebuilt several due to the camshaft lobes wearing down. We believe it was a bad batch of cams installed, but no bulletin or recall to my knowledge yet.
Old Mar 25, 2013 | 04:51 PM
kretty's Avatar
Happened in my 06 classic too.
https://www.performancetrucks.net/fo...-514292/page2/
There is a pic of the cam on page 2
00loudchevy
Dec 3, 2015 05:54 PM
Avalanche2002
Nov 30, 2015 07:31 AM
bearden86
26
Nov 15, 2015 03:58 PM
trevorh1
Sep 27, 2015 08:47 PM
sTNT971
Sep 26, 2015 04:22 PM
