tri pod pillar gauges
Old Jul 19, 2014 | 11:28 AM
brizzle815's Avatar
Default tri pod pillar gauges
Im wanting to add some gauges to my truck.
Fuel pressure
Air/fuel wide band
Possibly oil temp
I only found the tripods in black for my silverado. My interior is beige. Does any one know where I can order beige color tri pod. Or do I need to just order paint and paint them. If I go the paint route do I need to clear?
I also had a question about where to tap for fuel pressure. Im going notrouis soon tapping for fuel on the passenger side fuel rail. Is there an apadtor or fitting to tap into shrader valve for gauge and notrouis fuel.
Thanks for any tips and advice.
Old Jul 19, 2014 | 12:15 PM
05GMC4.8's Avatar
i have a dual not a triple pod. you will need to paint to match, no need for clear just find the color that closest matches your interior color. as far as clear, mine isn't clear coated. for gauges, I have fuel pressure, and had nitrous pressure but now vacuum/boost pressure.
for fuel pressure u can pull off the fuel rail just need to remove the valve. not sure on the size port for your truck where the Schrader valve is but its usually a 4AN male so you would need a female to male with an 1/8 inch npt port on the side to fit the sensor for the pressure gauge into. this is how I did mine when I had nitrous. when I removed the nitrous I just used a 4an cap to block the fuel out but my fuel pressure gauge is still there and no leaks. check out some nitrous suppliers, they will have exactly what ya need as far as fittings.
Old Jul 19, 2014 | 03:11 PM
brizzle815's Avatar
Thanks for the reply.
Do you know if triple will fit?
I read somewhere triple doesn't fit rcsb
Old Jul 21, 2014 | 07:26 PM
MustangPunk's Avatar
Autometer triple pod fits fine in my RCSB.. Only thing I've read is trucks with a speaker on the pillar don't come in triples if you still want the speaker if I recall..
Old Feb 23, 2015 | 08:02 PM
06boosted5.3's Avatar
use SEM paint. it will last a lot longer and will match a lot better. I used it on mine and we use it in the body shop
Old Feb 23, 2015 | 08:03 PM
they do have this version out currently
Old Feb 26, 2015 | 01:12 AM
KleanKustoms's Avatar
Glow shift has all three colors for our trucks.
Old Feb 26, 2015 | 10:24 AM
walledition's Avatar
im looking for a dual in color tan, cant find any, does anyone know where i can find one if not a good paint to buy a black one
Old Feb 26, 2015 | 12:52 PM
terravast4's Avatar
i just bought mine black and painted it..autozone sells interior paints that match pretty good
wrb002
Aug 31, 2015 12:00 PM
vipergtrdj
Aug 6, 2015 10:19 PM
ZONES89RS
Jul 22, 2015 12:35 PM
maxspeed05V
Jul 19, 2015 07:08 PM
Atomic
Jul 11, 2015 03:51 PM
