tranny sucks after putting in 4.10's
Old Apr 28, 2009 | 08:23 PM
fast84's Avatar
I also thought I was having tranny trouble after the 4.10 swap. And I had a hypercrap too. Then I sent my stuff down to Wheatley,told him what my problems were, and BAM!!! it was fixed. Two thumbs up to Wheatley!!!!!
Old Apr 28, 2009 | 08:30 PM
RST's Avatar
RST
Originally Posted by 1fstrst
Hypertechs can also help you get out of speeding tickets!!!!!
Old Apr 28, 2009 | 08:35 PM
SimpleManLance's Avatar
they also make a great paper weight!
Mangled03gmc's Avatar
Baltimore Whore
Retune will be needed..Black Bear Performance FTW The HPP will only recal the speedo.
Old Apr 29, 2009 | 12:17 AM
Low_LSX's Avatar
Formerly Low_LQ4 - 6/6/10
Actually I thought that adjusting for gears was one of the few things that the Hypertech was capable of
I think it can. You just have to go to the trans setting there should be something for the gear ratio. IRC
Old Apr 29, 2009 | 12:40 AM
AKlowriderZ71's Avatar
11 Second Hall Moniter
I had a Hypertech once. You can use it to change the transmission shift points after a gear swap. It will do more than correct the speedometer.
Old Apr 29, 2009 | 07:55 AM
5.3WT's Avatar
Thanks for all the good info guys! The hypertech can change the full throttle mph shift points. My truck is stock, I dont drag race it. I normally drive it fairly slow. I just want it to downshift first gear if I am below the shift point rpm for the appropriate gear. It wants to drop one gear, not two if needed. For example, if I am going 50 and i floor it, it will go to 3rd, not second. This is annoying for the times when I do want to move out.
Old Apr 30, 2009 | 12:56 PM
S/C Z71's Avatar
Banned
Hyper....junk!
Oobray
Jun 13, 2022 03:38 AM
AHelm3
Apr 8, 2016 07:51 AM
Aboss
Aug 11, 2015 09:05 AM
Cowboy Tom
Jul 21, 2015 10:29 PM
