TM-How to remove 80%
Hey guys-I just recently purchased HPTuners with the enhanced interface. First impressions the program is awesome-lots of stuff you can change. I've been reading about TM a lot in the past few days-however i can't figure out how to just remove 80%. Also im confused as how to remove the engine TM. Another thing i've been looking at is disabling dtc's, this is done in the scanner correct? Any suggestions will be greatly appreciated- i plan on having a full day of tuning tommorrow!!
This post should answer your question-it did mine?
https://www.performancetrucks.net/fo...d.php?t=360764
Set all your tables the same as what moregrip has provided.To just remove 80% I multiplied the values in the Retard vs. %Torque Reduction table by .2.
Example: the first value was 9(9x.2=1.8)I used 2.
In the big pic Flyer provided he has 50% removed.
Hope this helps.
Hope this helps.
Alrighty thanks for the help i think im getting it-Although im gonna remove all engine tm i think. How do i go about removing like 75-80 percent trans. Or is this impossible? Thanks for all the help again.
SlvrSierra4.8
Oct 1, 2015 09:39 PM
69z-28
Sep 21, 2015 07:31 AM
