Timing Tables
Old May 2, 2008 | 10:26 AM
A-Dub's Avatar
Default Timing Tables
I use HPT. In my previous Fbodies, when I tuned timing, I focused on the high octane table since the car ran on premium and that was the first referenced table in the PCM.
On my truck, it came from the factory designed to run on 87. Does that mean the high octane spark table is for 87 octane or does the PCM reference the lo octane table first?
Old May 2, 2008 | 10:35 AM
Stoichiometric's Avatar
The pcm interpolates between high and low tables based on knock activity. If you have no knock you are running off of the high octane table.
Old May 2, 2008 | 10:58 AM
A-Dub's Avatar
Thats what I figured.
Thanks
Old May 2, 2008 | 11:20 AM
SS_bnoon_SS's Avatar
There are a couple of different ways to tune it too. What I like to do is zero out all of the spark adders/subractors such as IAT, coolant temp, etc. and copy high octane to the low octane table so that no spark correction is happening. Then you can concentrate on one table only for actual tuning, then re-enable those other ones after tuning has been done on the main table (for safety sake).
Old May 2, 2008 | 12:09 PM
foff667's Avatar
LS1TECH Sponsor
You should also be able to log the knock learn factor in the scanner as well so you know which table the pcm is leaning towards.
kr1s
Aug 24, 2015 05:34 PM
smokeshow
Aug 23, 2015 08:23 PM
Boombastic
Aug 5, 2015 11:38 AM
lxcoupe
Jul 14, 2015 10:14 PM
jrplz
Jul 9, 2015 12:07 AM
