Ticking @ WOT?
Old Sep 30, 2010 | 08:43 AM
blackjack325's Avatar
Default Ticking @ WOT?
So ive had my truck tuned for a while now...
Been noticing a ticking/clicking @ WOT. Doesnt do it all the time though. Retune? Needs more fuel, less fuel?? HELP PLEASE
Thanks
Old Sep 30, 2010 | 08:49 AM
BlackGMC's Avatar
Resident Retard
are you sure it is not gas ping?
Old Sep 30, 2010 | 09:01 AM
gas ping? no idea, it clicks or ticks @ WOT thats all i know... but what could it be? tuning issue?
Old Sep 30, 2010 | 09:35 AM
outlawz2004's Avatar
What octane fuel are you tuned for? If less than 93, you could try putting a higher octane in and see if it goes away. If it does, yes you will need a retune or use a higher grade of fuel.
Old Sep 30, 2010 | 10:15 AM
i am tuned for 93 and have always used 93.... the only time my truck had anything less was the day i drove it out of the dealership
(cause i doubt they filled it up with premium) lol
Old Sep 30, 2010 | 10:34 AM
baSICK5.0's Avatar
im thinkin the same thing. thats what it sound slike anyways. Do you buy fruel from the same place every tiem by chance?
myabe the guy has your timing off and your not putting enough octane in it,
Old Sep 30, 2010 | 10:41 AM
i usually get gas at 2 different places. shell or stripes
unless im out of town. It doesnt ping all the time though, it does it sometimes. on the same tank of fuel
Old Sep 30, 2010 | 10:44 AM
Mangled03gmc's Avatar
Baltimore Whore
Pull plugs, check them, esp the driver side.. Sounds like PING to me
Old Sep 30, 2010 | 10:45 AM
hmmm.... ok, check this out. About 6 months ago or so, i had a local POS shop install my converter. They lowered the tranny, but had to unbolt the headers and cut my Y pipe. Guy did messy *** work, cut one of my tranny lines.
When i brought it back home, it was misfiring, So i started pulling out my cables and found a spark plug completely shattered. Changed that plug and 1 more that the ceramic looked cracked. But i didnt check the rest. Could a cracked spark plug cause the pinging im hearing?
Old Sep 30, 2010 | 10:49 AM
Baltimore Whore
It could, but if the plug was cracked, wasn't sparking you would have a ses light on.. easy way to find out is to go check all them then...
