Throttle body question
Old Feb 18, 2015 | 09:46 AM
fastoyzz's Avatar
Default Throttle body question
Fixing to 6.0 swap my 06 silverado. Using a tbss intake with a 90mm throttle body. Which one do i need to use the gold blade or silver blade one? They open different ways and was told it could possibly lock up the computer. Anyone heard of this?
Old Feb 18, 2015 | 09:17 PM
DrX's Avatar
DrX
They will both work, with an adapter.
Old Feb 19, 2015 | 04:06 PM
fastoyzz's Avatar
Cool man thanks!
Old Aug 10, 2015 | 08:29 PM
OHsixLS3's Avatar
Which throttle body did you end up using? Gold blade or Silver blade, and how did it work? I heard the same thing about one opening the wrong way. I picked up a silver blade part# 12570790, it does open the opposite way that the 87mm one I have from a TBSS does. I have not tested it yet to see if it works, I need to get a X- link first.
Old Aug 10, 2015 | 08:30 PM
OHsixLS3's Avatar
The adapter you are talking about, is it the X-Link?
Old Aug 10, 2015 | 08:32 PM
DrX's Avatar
DrX
Yes....
Old Aug 10, 2015 | 08:37 PM
OHsixLS3's Avatar
Yes....
So with the X-Link I can run either throttle body gold blade or silver blade in the NBS trucks? Does one work better than the other? Thanks in advance for the info
Old Aug 10, 2015 | 08:54 PM
DrX's Avatar
DrX
Silver will open slightly less. Most use gold now.
Old Aug 10, 2015 | 09:17 PM
OHsixLS3's Avatar
Ok thanks for the info on that. So I should look for a gold blade throttle body and get rid of the silver blade TB . Do you have a part # for the gold blade TB I should look for? Thanks again I really appreciate it.
Old Aug 10, 2015 | 11:08 PM
DrX's Avatar
DrX
Most use gold because you can get them new on eBay for around $150. The silver are more rare and usually go for at least double that. No reason not to use the silver. I think the silver may be a little more stable electronically based on my testing.
