Th400 and no speedometer
Old Jun 5, 2015 | 02:26 PM
121's Avatar
121
Default Th400 and no speedometer
Put a th400 in my rcsb and would like a speedometer. What's available I've seen a few different control boxes but figured I'd ask before I pull the trigger.
Thanks for the help
Ryan
Old Jun 5, 2015 | 03:38 PM
George C....'s Avatar
Formerly ScreamingL
abs sensor mod
Old Jun 5, 2015 | 04:59 PM
LSX Power Tuning's Avatar
I had a speed sensor put in my th400, it looked like it was done with all GM parts but Im not 100% sure.
Old Jun 5, 2015 | 09:25 PM
Call your nearest gm dealer and order a speed sensor, reluctor wheel and electrical pigtail harness for a 1988-90 c1500 4.3 v6 TH-400 auto tranny or if that confuses them tell them a 90 model SS454 with 400 auto tranny.
Pull the tail housing remove the worm gear drive and chunk the drive sender. Heat the tone ring up with a torch then carefully slide it on. Install the sender into the tail housing wire it up and ready to go all GM parts.
Old Jun 5, 2015 | 09:36 PM
121's Avatar
121
Default Sgi-5
I've been told all that is obsolete.
So what about the sgi-5?
Old Jun 5, 2015 | 09:43 PM
Formerly ScreamingL
easiest way is to just use the front ABS sensor and have the revs per mile corrected to match the correct speed of vehicle
no reason what so ever to over think and spend more money then needed
Old Jun 5, 2015 | 10:30 PM
Use part numbers check ebay. I have a brand new gm speed sensor been ratting it back last 20 years for this reason. For that rainy day project.
Old Jun 5, 2015 | 10:31 PM
What year RCSB?
Old Jun 5, 2015 | 10:52 PM
121's Avatar
121
Default Speedo
It's a 2007 nnbs. Idc what it cost I just want my speedometer to work. My trans builder who is ba can't get it. I called my dealer and no go there either. That's what makes me wanna try the part number above.
Rcsb s475 370ci th400 with a tbrake with bank
Bogarts 29.5x10.5x15 . It's to legit to not have everything working.
Old Jun 6, 2015 | 12:24 AM
gamble686's Avatar
Are you intentionally ignoring George?
