<TECH ONLY> How to tune for a higher stall converter
Old Sep 7, 2006 | 11:23 PM
1slowsilverado's Avatar
Originally Posted by dewmanshu
LOL yeh like ALOT=TONS, instead of 23 maybe 90 or even 98. Mine is 98.
Would this be the appropiate thread (<Tech Only Specific>) to discuss why we would turn on or off the Shift Lock with a new converter? Why do you turn yours off 1slowsilverado? Obviously more HP and cheaper converter, it will not like it, but a good quality converter can handle it. Does it help or hender? installing a higher stalled converter makes what difference in turning this off?
Depends what your using your truck for. Shift Lock is default in the pcm for trucks. Its more for towing mostly, Now if you have a Stall rated for towing go a head and leave it on, But keep in mind your TCC Apply speed will over ride the shift lock when not in tow/haul.. Not everyone knows how to tune a Stall and might be reading this as the bible. So I thought I would through it out there. I use my truck for track days mostly or to work if its raining. FWIW I dont lock my verter at all.
Old Sep 11, 2006 | 02:39 PM
TravisH's Avatar
should the converter remain unlocked through a 1/4 mile pass? What would be a good mph for it to lock under wot? 100? 110?
Old Sep 11, 2006 | 05:34 PM
Wilde Racing's Avatar
How do I change this text
I always "thought" it would be better to lock a converter ASAP. But I don't think that is true. From what I understand you would only lock the converter if you red line before the end of the 1/4 mile with it un locked.
Now my truck "Feels" faster when my ART CARR converter is locked, (when locked I would still see 400 rpm slip)
I have also heard that you want you shift to happen at peak HP rpm, and you want you rpms during the shift to drop to your peak TQ rpm. That is why I shift at 5200.
I also think it has to do with your set-up, Turbos like engine load...........
Like I said I'm not sure if any of this is true, so take it for what it is worth. Once my ideas are proven wrong I'll edit this post so others won't be miss-guided.
Old Sep 11, 2006 | 09:35 PM
Locking the converter when racing will slow you down and cause you to lose TQ.
Old Sep 12, 2006 | 05:11 AM
04GIBBS's Avatar
Default converter
Is it better to go with a Converter then to a 6spd? I have a Joe gibbs 5.3 supercharged truck and want more out of it and I think the factory converter is hlding me back?
LCHEE
Oct 24, 2020 04:10 PM
Castro45
24
Jul 31, 2015 07:13 PM
KyleW707
Jul 29, 2015 08:17 AM
lo&sloSierra
Jul 24, 2015 07:03 PM
ZONES89RS
Jul 22, 2015 12:35 PM
