Tech II not able to connect???? WTF?
Old Oct 23, 2009 | 05:29 PM
ForcedTQ's Avatar
Question Tech II not able to connect???? WTF?
Allright, I have tried multiple Tech II's to ensure it's not an equipment issue, I just cant seem to get them to connect to the truck's computer!!! My EFI live V2 connects up and functions perfectly, loggs, DTC's and the like. Any idea's on what I should look to so I can get the Tech II to work? I need to run the ABS bleeding sequence and get rid of this horrid sponge pedal !
Old Oct 23, 2009 | 05:32 PM
AKlowriderZ71's Avatar
11 Second Hall Moniter
Blown cig lighter fuse?
Old Oct 23, 2009 | 05:38 PM
ForcedTQ's Avatar
Thumbs up
Wouldn't that kill the OBDII port all together? Meaning I don't have an explanation as to why my EFI Live V2 works fine?
Thanks for the idea though!
Old Oct 23, 2009 | 05:54 PM
No, it just kills the pin for 12V that powers your scan-tool.
Old Oct 23, 2009 | 06:04 PM
ForcedTQ's Avatar
Thumbs up
Well, since the V2 is operating and my cell charger works, I'm going to assume the 12V pin is hot. Is that a correct assumption?
Specifically when I tried to pull codes or perform an operation, it would try to do what I asked it, then say cannot connect to vehicle or something of that nature.
Old Oct 23, 2009 | 06:23 PM
hmmm....
The cig lighter outlet is fused seperately from the accessory outlets that are right next to each other. The cig lighter fuse also powers the ALDL connector. So, basically, I dunno. I learned long ago never to assume.
Old Oct 23, 2009 | 06:51 PM
ForcedTQ's Avatar
Thumbs up
hmmm....
I'll check it out tonight when I get home, thanks alot for your help!
I know, I know, assuming ..........
Old Oct 23, 2009 | 07:47 PM
ForcedTQ's Avatar
Well, the cig lighter port has power. Now I'm stumped???
Old Oct 23, 2009 | 07:51 PM
Now it's time to bust out the Fluke meter and a schematic. What aftermarket accessories are wired to your harnesses?
Old Oct 23, 2009 | 08:12 PM
ForcedTQ's Avatar
I have absolutely no aftermarket electronics wired in. I was going to install my LC-1 in a couple weeks, but I want to get this figured out first.
